Hey @wrongwright
I downloaded your file and tried ‘follow active quad’, it worked perfectly for the top island.
Make sure you select the whole island and deselect the quad you auto aligned, then select it again to ensure it is the active quad.
Then you should have no issue with the follow active quad option.
You will need to repeat the complete process for each of the islands.
