Reply To: FPS problems
Forum Archive FPS problems Reply To: FPS problems
#99777
Wayne Dixon
    Hi Grace,
    Sorry you’re having frame rate issues.
    These files shouldn’t be difficult for your computer to handle but here’s a couple things to check.
    – Display in solid mode (not material or rendered mode) that will slow it down a lot
    – Limit the amount of 3d views and animation editors you can see. (each one takes your computer’s power when hitting play)
    – You can change it to ‘frame dropping’ > ‘sync to audio’
    – Is your computer doing anything else at the same time (spotlight indexing, 700 tabs open on your browser, editing that awesome YT video you’re working on etc)
    – Does it run slow on a new blank file (open it up, hit play, does it it 24fps)
    – You can also turn on simplify under the scene settings. (add this to your quick favourites so you can enable/disable really quickly)
    Hope that helps.
    Let me know how you go.
