Reply To: Fog disappears after gradient is plugged in
Forum Archive Fog disappears after gradient is plugged in Reply To: Fog disappears after gradient is plugged in
#74255
    That could be a lot of things, but maybe it’s the Scale of your Fog (the Cube). If you have Scaled it in Edit Mode, or at some point Applied the Scale, then that Object (and you are using Object Coordinates!) is huge (in meters), but the Gradient has a radius of only 1 meter, so in the scene it is so tiny that you can’t see it.
    If you Scaled in Object Mode, then, as far as the Object Coordinates are concerned, that Cube is still 2 x 2 x 2 meters, so the Gradient ‘fills’ (meaning it is not zero in) most of the Cube.
