@frikkr sorry, I didn’t amswer, because I couldn’t think of a way to do this. If you want to make a cookie, you can shape the dough, but once you bake it, the shape is set…
The sim has special files for each frame, but they are not keyframes. More like data, where each voxel is, if that makes sense.
I tried using the AnimAll Addon, but that doesn’t work either.
Just tested @3dioot ‘s suggestion, but couldn’t get that to work either, although that could be just me; first time using Alembic..
So, to recapitulate, as far as I know, it is not possible to edit the fluid sim in any way.
Maybe somebody else knows a way to do this?
