Reply To: Fixing object orientation/parent to allow proper animation
Forum Archive Fixing object orientation/parent to allow proper animation Reply To: Fixing object orientation/parent to allow proper animation
#88125
Jeff Bellune
    >This is why I prefer to use armatures.
    I actually tried using an armature earlier on in my adventure, but for whatever reason, it suffered from similar positional and rotational problems. I think it has something to do with the offset origin and the parenting structure, but it could also have just been user error.
    Armed with the knowledge I’ve gained here, I set things up with an armature for the wiper and got it to work. It seemed more difficult to get everything lined up and positioned correctly, but the end result was the same.
    What advantage(s) do you get by using an armature vs. positioning the geometry itself, please?
