Forum Archive › Final Result › Reply To: Final Result
My first guess would be the normals from n-gons. Select the entire area in edit mode, and press alt+n->calculate outside. I believe shift+n is the direct hotkey, but I always use the normals menu from alt+n. Also it would help to see your node setup
