Reply To: Extrapolation Mode through Channel selection
Forum Archive Extrapolation Mode through Channel selection Reply To: Extrapolation Mode through Channel selection
#58362
Wayne Dixon
    If you are using Right Click Select like I am, the context menu is enabled with the W key.
    So it works in a similar way after that.
    With the Greyed out options, do you have any channels locked?
    It seems there might be a small disconnect with the behaviour and the UI.
    If a single channel is locked – it is not greyed out in the context menu or channel menu, but it does not work (because of the lock)
    Whereas, if the entire group is locked – both the menus are greyed out.
    Which is more intuitive imo
