Reply To: Everything goes haywire after adding the small details on and around the buttons
Forum Archive Everything goes haywire after adding the small details on and around the buttons Reply To: Everything goes haywire after adding the small details on and around the buttons
#93326
Craig Barrett
    I had already checked the normals and removed all but the bevel modifier, so it wasn’t those things.  But I went back to a previous save and did that section over and it worked well the second time.
    I encountered another very bizarre behaviour with the screws later on.  I made a small cylinder to make holes (otherwise the groove in the screw was getting filled with the console body).  I was adding a boolean modifier in the locations I wanted and then applying it so that I didn’t have to create a set of holes to use and hide.  The very last hole caused the front of the console body to “grow” a massive section out to one side.  I then noticed there was some “warping” in the rendered result of the front of the body, artifacts of the n-gon.  I added some edges to create quads in the areas where the warping was happening and the warping went away.  And when I applied that last boolean there was no longer a big extra piece appearing from the front of the console.  That’s some very weird behaviour since the area that was “growing” when I applied the boolean earlier didn’t seem linked to where the hole was being made, but perhaps it was somehow linked to the area where I added the quads on the front to reduce the warping.  Hopefully I’ll learn more when I go through the modifiers video on CGCookie and the fundamentals of mesh modeling videos.
