#35853
Thibaut Bourbon
    @thecabbagedetective It looks awesome! The cut holes are super crisp and I love the extra effort you put on inset lines. That was worth the struggle. Now my turn to catch up!
    Regarding your GPU memory question, I’m far from being an expert so take that with caution but:
    – Did you check the size of your scene in term of memory and compared it to your GPU’s ? If you’re lacking memory, I’d suggest to split your scene into different layers and have an extra composition work afterward.
    – I don’t think the samples amount is the issue, when the memory fails it is usually during the pre-processing stage.
    – On the Simplify menu there’s options on the texture size limit that might be helpful (I never tried these, would be happy to know the result actually). Also maybe put a threshold on the subdivision, things tend to go out of hand when you have 1.5M+ verts and subsurf on .
    Aside from that I don’t really see what could be the issue. Could you take a screenshot of the error message (if any?)
