Reply To: [ENDED] BC1-1808 – August 2018 Class Homepage – Getting Started with 3D Modeling & Blender 2.8
Forum Archive [ENDED] BC1-1808 – August 2018 Class Homepage – Getting Started with 3D Modeling & Blender 2.8 Reply To: [ENDED] BC1-1808 – August 2018 Class Homepage – Getting Started with 3D Modeling & Blender 2.8
#37985
Wilco Wilbrink
    @vortigaunt4 I hope I’m not to late, but if you haven’t figured it out yet: You could export the scene as an Alembic-file, but you could also copy and past (most times) your object from Blender 2.8 to Blender 2.79b and upload your scene from there with the sketchfab plugin.
    1. Just select all objects in Blender 2.8 (I don’t know if you should select the lamp and the camera. I’ve not tried that)
    2. Press CTRL-C
    3. Start an Blender 2.79 (if you haven’t already)
    4. Press CTRL-V, and probably the scene will copy.
    5. You most likely have to add new camera’s and lights if you want to, but then again, I don’t think you need them for sketchfab.
