But I want the texture from the dynamic paint not from the array as that’s too perfect it also means I have to try and match two separate animations
It looks like I’m back to manually gridding the ground plane and sub diving those squares to get the coverage I need at the resolution I need without killing the computer.
I can’t believe there’s not a better solution to this tho. I really should probably give up on trying to solve this as it clearly beyond my skill level and I’m sure any attempt I make is going to be sub par and won’t be able justify the time I’ve sunk into this.
