It’s an interesting topic, I can definitely relate to it. I don’t draw much either, I could easily admit that I lack basis in this field and it can be a hinder when looking for a job. Indeed nowadays company require the candidate to master the complete “from sketch to final render” suite, which is not an easy task…
I can of course only speak from my experience, but I choose to get basic knowledge on most of the fields covered in CG, and to strenghten only few aspect of it. I can’t draw, that’s a fact, but I took sketching lessons so I can at least throw ideas on paper and get a decent perspective for exemple. Same with texture painting, I barely use it, mostly because I chose not to for the moment. But I know how it works and would be able to use it if need be.
I would suggest to build a portfolio with stuff you’re really good at, even if it doesn’t include sketching and/or texture painting in your case. But during interviews, when these topics are mentioned it’s better not saying “I can’t draw” or “I don’t do texture painting”. Instead emphasize that you know how “Substance works but you may need to refresh your memory quickly”, or that you’re taking drawing classes. Be positive on your weaknesses.
Hope it’ll help, good luck!
