Reply To: Do you use any shortcut to reduce brush size quickly?
Forum Archive Do you use any shortcut to reduce brush size quickly? Reply To: Do you use any shortcut to reduce brush size quickly?
#23752
Tim Von Rueden
    Yes, on a mac I press down “control and option” and then press down on the tablet with your pen and either go horizontal or vertical on the surface depending if you want to change the size or the hardness of the brush!
