Reply To: Do you happen to know how toon artists get the outlined look with the toon shaders?
Forum Archive Do you happen to know how toon artists get the outlined look with the toon shaders? Reply To: Do you happen to know how toon artists get the outlined look with the toon shaders?
#89490
Dwayne Savage
    It depends on your use. In a game engine you use an inverse hull technique(the solidify mid that Adrian mentioned). If you’re staying in Blender then you can use freestyle(that Martin mentioned) which is a post process effect and can be used as a render pass too. Then there’s the newer line art modifier for grease pencil.
