Reply To: Do light probes effect the performance? Also are there any other situations of using light probes rather than emissive obj…
Forum Archive Do light probes effect the performance? Also are there any other situations of using light probes rather than emissive obj… Reply To: Do light probes effect the performance? Also are there any other situations of using light probes rather than emissive obj…
#22832
Jonathan Gonzalez
    Light probes effect performance but it depends how you use them. All they do is sample light, they don’t cast it. I used an emissive map because it can provide a perfect example of when to use light probes.
    Light probes are best used when transitioning from one dark area to a well lit area using moving objects.
