Reply To: Displace animated texture Z axis
Forum Archive Displace animated texture Z axis Reply To: Displace animated texture Z axis
#52265
    No, true displacement doesn’t work in EEVEE (yet).
    If you want to use EEVEE, you could try this:
    Connect the Displace Modifier to an Empty. Set the Displace Texture to your Image and use the Object Texture Coordinates with the Empty as the Object. Something like this:
    Then you can animate the Empty.
