Reply To: Different result from the tutorial when using Inset Boundary (17:40)
Forum Archive Different result from the tutorial when using Inset Boundary (17:40) Reply To: Different result from the tutorial when using Inset Boundary (17:40)
#101036
    Hi Bsam,
    There is probably an issue with your Topology.
    The usual suspects are ‘double Vertices’ and/or inconsistent Normals.
    Go back to before the Inset and Select All with A and then M > Merge > By Distance, directly followed by SHIFT+N (to fix the Normals).Then try again.
    Let us know if it still doesn’t have the desired result.
