Reply To: Difference between angle vs area UV’s
Forum Archive Difference between angle vs area UV’s Reply To: Difference between angle vs area UV’s
#52936
Shawn Blanch
    I hope that helps explain the area stretching better. I’m not a pro at texturing by any means. I typically just unwrap, check the angle stretching and size my UV to make use of all of the UV editor bounding box so I can utilize the most of whatever texture I plan on and move on. I can see the benefits of keeping tabs on the area stretching though if you were planning on texturing multiple objects of different physical size.
