Hi Brandon, not sure if I get your question right. Don’t worry about the rabbit hole, this topic is hard and takes time (i’m still not though the complete bundle and I’m still struggling after a long time.) But for overshooting an action (making an action delay it’s end a little, you can either move the keyframe a little or even better, use the bezier curve to slow the end (making your curve continue a bit in the direction it was going past the keyframe before going back the other way. My feeling is that this helps you give you more granular control.
