Reply To: Deform still checked
Forum Archive Deform still checked Reply To: Deform still checked
#99344
Dwayne Savage
    Correct me if I’m wrong Wayne, but I believe Wayne uses right click select. So some of his hotkeys are different because of this. Also I’d recommend using the hotkey shift+w->Deform followed by F9->and change Type to disabled. Note: Instead of the F9 you can expand the adjust last operator box in the bottom left hand corner of the 3D Viewport. If you don’t like hotkeys you can access this thru the menu: In pose mode it’s Pose->Bone Settings and in edit mode it’s Armature->Bone Settings.
