Reply To: Default Viewport shader color
Forum Archive Default Viewport shader color Reply To: Default Viewport shader color
#80466
    You can make that default file the Startup file by going to File > Defaults > Save Startup File, if you haven’t done that already, but apart from that…
    You can change the color of the Viewport (‘permanently’), but not the fallback Material…
