Reply To: Cutting the corners on the Cube
Forum Archive Cutting the corners on the Cube Reply To: Cutting the corners on the Cube
#27923
alimert
    Loop cut + slide to  draw a 2d cube on the corners of the cube. after that bevel that with profile settings as 1.000. last the is to inset that with ctrl.
    the last thing to do is to CTRL + SHIFT + B the corners and your cube is ready. (not including two cuts middle of the cube, but its the same process.)
