Reply To: curve modifier causing deformation in dominoes
Forum Archive curve modifier causing deformation in dominoes Reply To: curve modifier causing deformation in dominoes
#25788
dirge0matic
    I already intended to break them apart anyway and reset there centre to geometry.
    the main thing was whether there is a way to use the curve modifier and array that doesn’t deform the geometry. the only other way i have found is using motion paths but that wont allow the models to be broken apart into individual bits.
    if its a manual repair job that’s fine, was just surprised there wasn’t a “deform” button on the curve modifier.
    thanks
