Reply To: Create new empty to rotate cube around
Forum Archive Create new empty to rotate cube around Reply To: Create new empty to rotate cube around
#32084
pieriko
    You don’t need to use all these constraints.
    Here is, if I’ve correctly understood your need the corrected blendfile, with a rapid animation.
    Just keep the first one then,
    1) unlock your empty X location
    2)duplicate it and move it 2 blender units on the X axis.
    3)Parent the first empty to the duplicated one.
    4)Offset new empty keyframes so that animation doesn’t hapened at the same time. Repeat the process for any additional empties.
    Then work on your animation.
    The cube is child armature if child of the first empty thanks to the constraint
    Empty child of Empty 2 and empty 2 child of empty 3….
