Reply To: Copy rotation bone constraint
Forum Archive Copy rotation bone constraint Reply To: Copy rotation bone constraint
#90968
Tom Fransson
    Hi Martin
    You mean my first example this one:
    If I rotate Target_02 45 degrees around local Y. And then rotate Target_01 around local X.Then the Owner will rotate around its local X. But, if I instead rotate Target_01 around local Z. Then the Owner will not rotate around its local Z.
    And my second this one:
    For Euler XYZ order, then if I rotate Target_02 -90 or 90 degrees around local Y. Then we get a gimbal lock. And as a consequence of this, when I rotate Target_01 around local Z or local X
    Am I right? I’m starting to get abit lost (and it is entirely my own fault), if your wondering 🙂
