Reply To: Constraint to F-curve
Forum Archive Constraint to F-curve Reply To: Constraint to F-curve
#31582
amirshehata
    Hey Johnathan,
    The issue is not the plugin itself. It’s the behavior that I’m seeing from blender:
    1. Create a tracker object in the video clip editor
    2. Add trackers
    3. Track the footage
    4. link to empty
    After step 4, I now have a set of empties, each one has a follow track constraint pointing to the respective tracker. However, when I try to do “constraint to f-curve” to make the empties independent of the camera. That doesn’t work. No key frames are created.
    If I copy those tracks to the “Camera” tracker object, then “constraint to f-curve” works.
    Is that expected behavior? or is there an extra step I’m missing when working with something other than the default “camera” tracker object.
