@splat21 Great work 👍! As far as the shafts are concerned, Vadim @harbinger_ua has it said here:
You can make the shafts a bit longer as it is indeed for a horse. But not too long as it might ruin the overall balance of the silhouette. I would tilt at least the backside of the cart a little bit (as did for example @vincav81 here). Some hard edges (for example at the wheel rims) could be slightly beveveled (but only on segment!) so that it doesn’t look that razor-sharp. Details like bolts are something that you can model in a more detailed version an then bake into a texture for the low-poly-model. I think that’s what Kent @theluthier also has in mind when it comes to such smaller parts.
@splat21 I’m looking forward to your further progresses with the cart 😀!
