@noonespecific That’s a good start and welcome to the team 😀!
Can I tag this as your
Homework Submission – Week1 – Vase B
@theluthier
since the next livestream is already tomorrow here?
I would just slightly bevel (with only one segment) hard edges as at the top rim of the vase so that it doesn’t look like razor-sharp. Also a an additional loop cut through the loop of bigger faces directly below the narrow bulge (with a slight fattening (Alt + S)) would give a smoother result. You can also turn on “Smooth Shading” in combination with “Auto Smooth” (in the “Normals” panel of the “Object Data Properties Tab” of the “Properties Editor”).
