Excellent work @konstantinosk! These accents will work very well. You’ve earned full points from me this week 👍
One thing I should clarify: Could you add the masonry accents around the door as well? I did not make this clear in the asset list, for which I apologize.
Also some advice for model organization and structure: I recommend you treat each accent “area” as a separate model that can be mirrored for easy population on the rear of the house:
Each color represents a separate model that can be mirrored to the backside. This way you won’t have to model + sculpt + texture the rear side individually. And I think all 4 of these models can share the same texture if their UVs are laid out in the same texture space. But more on that for week 3.
