Reply To: COLAB2021 – WIP – lexicolopolis
Forum Archive COLAB2021 – WIP – lexicolopolis Reply To: COLAB2021 – WIP – lexicolopolis
#66298
Beau Kromberg
    Did some low poly sculpting to make the cobbles less uniform. Going to take a break until tomorrow and assess what more I should do. I’d like to pull the center bearing out into wood planks as well, but I don’t think I can afford the verts/tris.
    My Vert count is higher than I would like: 11.8k if Single User, but only 4.4k if we’re keeping Data Linking on. I can probably remove maybe 5-10 percent once UV is done as there’s a lot of hiding faces, but with data sharing on I need it all still.
