Reply To: Chapeline’s Polybook
Forum Archive Chapeline’s Polybook Reply To: Chapeline’s Polybook
#68791
Adrian Bellworthy
    @chapeline ,
    A very nice, well populated, and pleasant space. Good Job.
    I was reading the other comments above, I came to the same conclusions in the most part.
    After reading your comment about forgetting a few things and rushed to finish, If I may offer some advice, try and finish modelling before moving on to texturing and shading. The cupboard handles are small details that shouldn’t take to long to model. Lots of small errors will be noticed, one or two you might get away with. These things are easy to forget if you have to go back to the modelling stage.
    The things that stood out for me on first look,
    The gap from the kitchen worktop to the wall, highlighted by the dark shadow.
    The upper area of the room near the ceiling seems dark in comparison to the sunny shadows on the floor, at a guess and looking at the floor, I would say the roughness value is to high and this is probably true for most objects, lowering the roughness will help bounce the light around the room a little more, but not to low.  To be honest the floor looks a bit dull, if your using image texture maps , make sure you have non-color selected for the color space for everything except the color map.
    The table you said you googled the dimensions, did you google dimensions for everything, the chairs, the worktop, the cupboards etc., etc.? It does look a little small. Unless this is a commissioned render for Ikea, then it’s ok to scale objects to fit artistically. I would go for real world scale as much as possibly, it needs to be consistent across all objects to eliminate these problems, however as said, for artistic purposes it’s ok to scale a little.
    I’m not sure how you modelled the room it’s self, but I would scale a cube to the dimensions of the room then flip the normals to the inside, cut out the windows and extrude for thickness, then add a small bevel to the edges to soften the sharp corners. Looking at the corners where the wall meets the ceiling, especially above the window, the wall is in shadow but the ceiling is in the light. It looks like you have used a plane for the ceiling and another object for the wall, and the light is coming through a slight gap. The shadow in these angles is inconsistent all round the room.
    Hope this helps. Use the critiques as a tool to success, you’ll be doing commissioned work for Ikea in no time. 👍
