Reply To: Chap. 5 Using Hot Key F9 – or Shift Ctrl Z, Doesn’t Work with 4.0!
Forum Archive Chap. 5 Using Hot Key F9 – or Shift Ctrl Z, Doesn’t Work with 4.0! Reply To: Chap. 5 Using Hot Key F9 – or Shift Ctrl Z, Doesn’t Work with 4.0!
#84493
Patty Hatfield
    Oh…..I remember! the redo Plane only appears right after you add an object, but as soon as you click on the screen , the redo panel disappears. However…  pressing Shift Ctrl Z at same time brings up  four ways to view object: wire, solid, material, rendered.  But  does not activate hot key F9 to change size!  has this changed within 4.0?
