Hi Martin,
that you so much for the efford of explaining it to me. But I’m still not sure if I understand it.
I set up this little GM here:
So, I just scaled the Pivot Point by 0 and feeding it into the SetPosition Node. So what I assume now is the following.
The SetPosition Node uses the individual postion of the letter based on the Buttom Left Corner. So feeding 0 in the position slot aligns it to the buttom left corner. The not visable pivot point is in the exact center of the letter. I in my screenshot it rougly on 2.5, 3.5. So scale it by -1 set’s it to -2.5, -3.5. So what I basicially do is to move the Bottom Left Corner to -2.5, -3.5 wich is then the exact center of the letter.
Is that right?
Is there any way to visualise the value of the pivot point? Or the buttom left corner pint? Tried it in the Spreedsheet, but I was not able to visualize it
