Reply To: can’t subdivide any higher than 6
Forum Archive can’t subdivide any higher than 6 Reply To: can’t subdivide any higher than 6
#88699
    Hi Rob, that is a so-called soft minimum. It is done so that you don’t accidentally slide the slider too far and freeze or crash blender. You can type a number higher than 6 in the field. But be careful, each Level multiplies the amount of Vertices by approximately 4.
