Forum Archive › can’t set color to frame › Reply To: can’t set color to frame
It must be a theme setting then. Check in your User Preferences > Theme > Node Editor > Frame Node
Make sure the A (alpha) setting is not set to 0. If it is it means it will always be 100% transparent. The default alpha value is 0.8.
