Reply To: Can’t select top and bottom vertices at same time. Only top is selected
Forum Archive Can’t select top and bottom vertices at same time. Only top is selected Reply To: Can’t select top and bottom vertices at same time. Only top is selected
#83311
Dwayne Savage
    You just need to be in x-ray mode(Toggle on/off is Alt+z) when you switch to wireframe shading mode x-ray is on by default. In other shading modes you have to toggle it on.
