Reply To: Can’t get Shift K OR Ctrl X to work in vertex paint
Forum Archive Can’t get Shift K OR Ctrl X to work in vertex paint Reply To: Can’t get Shift K OR Ctrl X to work in vertex paint
#89480
Perry Harmon
    @Martin Bergwerf       “When I said try it on a default Cube, I meant, try it on a default Cube.”
    So, Martin. I’m unclear. Are you saying I should try it on a default cube?   Ha. Yes, I tried it on a default cube and it works fine. I’ll check that I’m in material preview mode and that the vertex color (Attribute Node) is connected to the material.  Thanks for you input.
