Reply To: Can’t edit this property from an override data block
Forum Archive Can’t edit this property from an override data block Reply To: Can’t edit this property from an override data block
#75869
autobodhi
    actually I’m having some other problems with this start file.  it seems that some things just don’t work properly like hitting i in the 3d viewer doesn’t bring up the list of options and it doesn’t key all selected objects, just the active channel on the active object if anything.  the copy paste function also only works on the selected bones and I can’t seem to box select or control select in the dope sheet so I’m constantly having to select everything one by one.
    I tried linking stomp to a new project and starting from scratch but the ctrl alt p to create proxy thing doesn’t seem to work unless I’m linking the wrong file?  it seems like the file setup is quite different than in the vid so the object and rig are stored separately but I can’t figure out how to get them both in there and joined up…
