Reply To: Can’t edit this property from an override data block
Forum Archive Can’t edit this property from an override data block Reply To: Can’t edit this property from an override data block
#75883
Craig Wieland
    so if you look in the object properties under Viewport display, and then click on the Axis box you will see that Stomp was made with the facing in the X axis. hope this helps.
