Reply To: Cannot find Principled BSDF
Forum Archive Cannot find Principled BSDF Reply To: Cannot find Principled BSDF
#75133
    Yes, it is as Martin says, that happens to me all the time. The reason seems to be that Blender has a grid 0, 0, 0 default where all the nodes pop into existence, and sometimes your view is off that 0, 0, 0 center point. Say you’re way out in a corner for example, and when you add the node, it pops in where it usually does but your not in that center, but you don’t know it because everywhere looks the same. So just hit A to select every node and period key in the numpad to fit everything into view and that should shed a light into  where that node is.
