Reply To: Cannot do outset
Forum Archive Cannot do outset Reply To: Cannot do outset
#78032
    Hi @cameramannz1986 ,
    You can’t see this in Face Select Mode, but I suspect that you have Double Vertices; maybe you Inset once and then you tried again to Inset with Outset enabled, but that immediately hits the outer rings that were created with the first Inset.
    That’s a lot of words, clumsily trying to explain this…
    Just select all and Merge by Distance.
    If that doesn’t work, maybe provide a link to your .blend
