Reply To: Can I do the same your operations using another object from Blender? If I try using, for example, the monkey, the texture…
Forum Archive Can I do the same your operations using another object from Blender? If I try using, for example, the monkey, the texture… Reply To: Can I do the same your operations using another object from Blender? If I try using, for example, the monkey, the texture…
#22668
    There’s nothing special about the gizmo – it’s just a 3D model like any other – and they all can be baked. But the gizmo does has its UV’s laid out which is required to see a baked result.
