Reply To: Can I create an ID mask for an object of multiple pieces? I have the rim, wheel, and treads joined together (using ctrl+J) for unwrap. When I use this technique, all the object are one color.
Forum Archive Can I create an ID mask for an object of multiple pieces? I have the rim, wheel, and treads joined together (using ctrl+J) for unwrap. When I use this technique, all the object are one color. Reply To: Can I create an ID mask for an object of multiple pieces? I have the rim, wheel, and treads joined together (using ctrl+J) for unwrap. When I use this technique, all the object are one color.
#25214
Jonathan Lampel
    For that, you could paint a ID mask manually. Here’s how to do it quickly:
    • In Texture Paint mode, turn on Face Selection Masking in the header
    • Select a face and hit Ctrl+L to select everything attached to that face
    • Switch to the Fill brush with a strength of 1 and fill the selection
    • Repeat with a different color for each piece.
    Hope that helps!
