Hi, thank you for your advice 🙂
I am currently undecided whether it should be a tablet with or without a monitor. I read that you can probably get good results with tablets without a monitor. I just imagine this is a little bit tricky, because you have to look at the main monitor while drawing / sculpting. I am also concerned because of cost reasons, I am still quite at the beginning and I did not want to spend more than necessary. As a maximum, I want not pay more than 350 Euros, if possible. Furthermore, I am unsure about the size of the tablet and I assume that a larger tablet is better for sculpting and drawing, isn’t it?
