Reply To: BSDF node setup doesn’t appear
Forum Archive BSDF node setup doesn’t appear Reply To: BSDF node setup doesn’t appear
#92050
    It depends on what software was used to texture the model. Each software uses its own method and they aren’t usually interchangeable. So Blender’s node system wont work natively in 3Ds max and vise versa. If a material is set up in Blender, it will only load up in Blender again when you import it.
