Reply To: Bridging the edge loops connect the different vertices and gives weird shape
Forum Archive Bridging the edge loops connect the different vertices and gives weird shape Reply To: Bridging the edge loops connect the different vertices and gives weird shape
#51324
    @ryzen7 Hi.
    This is happening, because the order of the vertices of the two edge loops is not consistent; one is going clockwise and the other anti-clockwise.
    You could, before connecting them, rotate the inner edge loop 180° around the Y-axis. That should fix it.
    Alternatively, enable the Loop Tools Addon (highly recommended!).
    Then if you go into the Context Menu, or look in the N-Panel under Edit you can Bridge from there, which not only gives you the Twist option, but also a Reverse checkbox.
    With F9 (F6 if you are still using Blender 2.79 or earlier), you can change those:
