There is a difference in the first bounce as you can see in his demonstration. Unless you mean the first drop. In the real world heavier objects probably will drop slightly faster, especially if we compare balls like a beach ball and a bowling ball. While it is true that all object fall at the same rate in a vacuum, to make them believable you should animate them in a way that you would observe in real life.
