Forum Archive › Boolean modifier doesn’t work › Reply To: Boolean modifier doesn’t work
Hi Samuel @samuelsw ,
Try moving the Cutter object around a bit, overlapping Faces are usually not a great idea. I actually suspect the Rotation of the Cutter is slightly off…
With that, I mean, that the ‘top’ Faces aren’t completely aligned:
