Reply To: Boat Baking Issue
Forum Archive Boat Baking Issue Reply To: Boat Baking Issue
#95183
Chunck Trafagander
    My pleasure! And you’re absolutely right, areas like the above image require more fidelity to better match the curvature of the high-poly model. In this instance, you may want to either add a couple more loops to areas that need it or try and move existing loops and edges to fit the silhouette of the high-poly model. I’m confident that you’ll start seeing better bakes as a result!
