Reply To: “Blender exploding shape key” advice.
Forum Archive “Blender exploding shape key” advice. Reply To: “Blender exploding shape key” advice.
#74976
    @Detcelfer It pains me to read about how persistent this multires bug was for you. I’ve definitely had experiences like this over the years where the bug continues to plague my sculpture…still, it’s never been a showstopper. One thing that I learned is that fixing the exploded verts on each level of multires helps to prevent it from persisting. Fixing at the lowest level first and working your way up.
    When I first experienced this issue, I would fix the exploded verts only on the level I was sculpting. Then eventually I’d switch levels and it would come back. Which makes sense because the sculpture’s shape (including exploded verts) is represented at every multires level, so any artifacts need to be resolved at every level to completely go away.
    If this helps it’s probably too late. But thanks so much for sharing your advice and experience for others to benefit! 🙏
